0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | does anyone have any suggestion for the lubricant to use on the window regulator or the window track on the window. Both had old grease which was hard and very sticky. have cleanded them up but was wondering what might be best to go back with. thanks for any suggestion you might have. Frank | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I use white grease that was made for my garage door.
I'll probably be moving this post to another forum. FYI.
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I've had good results with never seize. It can be messy, but you shouldn't need to replace the glass (and get into the mess) as often as the fleet trucks and off road equipment I used to work on. John | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | In what condition are your leather washers which ride in the channels? They look like rollers, but they do not roll. If your leathers are beat up, a slick trick is to use the aftermarket rollers.
