Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (55shaker, dt235sd, 1954gmc9314, Hotrod Lincoln, Bill Hanlon, ShopRag, Hush, lumbersawyer), 33 guests, and 1 robot.
Topics128,022
Posts1,055,274
Members48,418
Page 162 of 177 1 2 160 161 162 163 164 176 177
I drove the suckah'. Tomorrow, going to add new radiator support pads........unless I choose to drive it instead.
Craig
Ordered more parts and making plans with Terry B for some work days after I heal from hip replacement.
Big Bolt Forum Moderator
I had to pull the leaking radiator our and then found out it is not repairable.. .time for a new one!
Mike
I installed my two piece cardboard headliner in my 46 Chevy half ton. I did it myself and like the looks of it. Tomorrow on to weather stripping.
I took my '63 GMC 4000 with a 305 V6 to get dual exhaust installed.
Y
Olddog
Olddog
Y Offline
I have got nothing done, still trying too figure out exactly which 1948 GMC I have
Y
Olddog
Olddog
Y Offline
I got a 1948 GMC, you got a Chevy, or GMC?
Just did the same thing and yes, you can tell I did the installation!
1954 3600
I put my slightly improved health to the test on Sunday . I had the right axle break on the truck , at 70kph!
It took about 50meters to stop and was one of those times I wished I had a dash cam , as the rear wheel (with half an axle attached) trundled on by me .
After calming myself for a while , I waited for a friend to come past , I was sure one would , and yes some 40mins later , smile .
He took me home and we gathered the necessary parts and tools .
So the axle change was easy , getting the truck up off the ground was more difficult , then I found the U bolts had been ground away to almost nothing , so I wrapped a chain around the spring and axle and tip toed home (25km)
Got new U bolts made today and fitted them .
ALL GOOD ................ phew!
Small panel damage to rear fender still to repair .
Dusty, you are one lucky man.
Thanks Martin , yep , lucky the truck did not end up on its side .. especially as it was top heavy with the camper on .. that would have been untidy .
Not a bad ending to a potentially terrible failure. May the greater good luck gods continue to win out over the bad luck demons.
RonR
RonR
1970 340 Duster
1964 CJ5
Converting a military GMC 302 to full flow oil system. Drilled and tapped oil passage and tapped and installed a plug per the inliners guidance started reassembly of bottom end. Drilled steam holes on an 848 head for installation on a 62 Chevy 261.
1946 GMC Project
"Back-in-the-day Restore"
Well, I had a set of 4 new Goodyear Wrangler tires installed yesterday at Walley World. Paid to have 4 new valve stems installed as well, but while watching the tech go about his business I noticed that he wasn’t installing the new stems. I inquired why and he said the work order didn’t include them. Off to the office I went to ask what was going on. She showed him that I was correct, so back to the truck he went. In no time at all he was back in the front office to explain that there were no valve stems in the shop of the type necessary and specified in the work order. The assistant manager was summoned and, after being explained the situation, asked me if I could go out to another store and buy some and bring them back so they could finish the installation. I told him my only transportation was up on his rack. I suggested we could get for stems from Discount Tire, but I had no way of getting there. The manager quickly volunteered to drive me there in his Jeep, which he did. We quickly purchased 4 of the correct size valve stems, and he dropped me off at my house on his way back to Walmart. My wife and I had a Christmas party to attend an hour away and I was running out of time! He and I had agreed that he would take the stems back and they would finish the job, then would push the truck out into the parking lot, lock it up, and we could stop by on our way back from the party to pay the invoice and drive the truck home. Sure enough, when we got there after the party the truck was where it was supposed to be, and we quickly went to the service desk and settled up. It was a very unconventional way to get a new set of tires, but everything turned out OK in the end.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Finally took off the front passenger side caliper, got new ones , and installed both sides. While the wheels were off, I tried to remove play (it was about 45 degrees total, or 8 inches?) from the steering wheel... Half turn of adjustment screw did the trick.. did the rear cylinders last week. Tried to bleed the brakes and the calipers barely grabbed the rotors.. the dual master cylinder is old, and I need a proportion valve and residual valves, may just replace it. Still gotta rewire the truck, replace rear main seal, adjust valves, check timing.... Maybe next year.
Actually, this news is a week or so old. Ordered the new windshield wipers from LMC because NO ONE local sells wipers for a 56 year old truck. Since I couldn't get them locally, and the rain was coming, and the passenger side wiper had lost it's rubber.....
I had to get creative and pull the passenger side wiper arm. I ran for a few days of heavy rain with just thd driver side wiper working.
I have since received and installed both new wipers. Much better vision now.
I planed the oak boards for my 46 truck bed. Next I have to saw them to length and width, then do the routing on the edges and a final sanding. I am going to coat them with marine varnish.
Picked up a 4:10 rear end for my 1950 GMC one ton today, ending a three year hunt . Drove 200 miles ( one way) to get it. They said it had come in forty days ago, so keep looking gentlemen.
Nothing today, but been waiting for photos to post...
Oct 7th wedding for a friend's wedding.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Pulled out my 230 and dropped in a 292 on my 54...
Not today.
Gave the front end a good grease job , steering was getting a little firm smile
All good now .
Installed bearings, crankshaft, camshaft, and timing cover on the military GMC 302 rebuild after completing the full flow drill, tap and plug conversion and drilling a hole for the dipstick. Making progress.
1946 GMC Project
Picking up a load of tan bark for the yard. Another day of earning it's keep
2nd load:
Craig
Completed the restoration of the recirculating heater for my 1953 3100. I used the Brassworks heater core and followed the process from the forums.
Mike
1953 3100
The Gray Ghost
My Project journal
Z
hmmm.
hmmm.
Z Offline
I put back the battery hold -down bracket. Its been off for 15 years. TV said I should do it to prevent damage to the battery.
Then I looked at the fuel filter and determined it was filthy. I replaced that one with a new one. So I was removing the fuel line from the old filter and when I got the hose off the filter it whiplashed off and the hose clamp flew off and landed on an upper shelf eight feet behind me. Of course it took a half hour to find it, plus I needed a ladder to even search that high up off the ground. Job done. Let's go for a ride.
Working on bed now.
1949 Chevy 3600 (1)
1949 Chevy 3600 (2)
1949 Chevy 3600 (3)
In primer.
One wheel off for pinstriping, pulled plugs, fogged cylinders and reinstalled.
"Old Smokey'"
Been having a annoying hesitation/misfire under load at low RPM. 250 I6 engine. Replaced the plugs, plug wires, distributor cap and rotor....no fix. Points and condenser were also replaced recently. Turns out it was a defective condenser...holy crap, a $5 part causing all that BS... dang
[img]https://i.postimg.cc/DyFyzM5Q/SAM-0455.jpg[/img]
One rim painted, 4 to go.. hopefully i can get them to match fairly close.
"Old Smokey'"
Apart from cutting into the truck this is literally the first piece to be touched and ready to go back on as I tackle the driver side door opening.
Surprised the rear pockets were not available so made one up.
1951 3100 5-window
with a '55 235/floor mounted 3-speed
Some of the story in ODSS
Most of it in The Shops Area wink
just installed 3100 parabolic leaf set from speedway. I got the idea from looking over posts from this site and finding what big chevy 3600 done. Could not be happier with the outcome!
I owe him a big thanks that's for sure!
Built a rotisserie for my AD chassis out of a couple of cheap HF engine stands. Found the directions on YouTube. Super easy! I use my garage for wood working also. All my wood working machines are on casters so I can move them all to the side. On the rotisserie I can now spin the chassis up sideways and move it to the other Side when using the table saw, etc.
Had the day off for MLK day yesterday. Weather was real nice so I cleaned, gapped, and reinstalled the spark plugs. The old 216 smokes a bit and the plugs tend to foul frequently. Fired it up and it ran like a top. Drove it to get a haircut afterwards.
Chuck
1941 Chevy coupe
got my new radiator in yesterday on my 58, and also swapped out the stock 2bbl carb and manifold for a stock 4bbl manifold and quadrajet (off another 1967 327). Hopefully, this will get rid of my dead spot and if I keep my foot out of it, maybe increase MPG going down the freeway....
Mike
Second wheel painted up, third wheel removed. Tried that darn tight front left again, got one nut broken free but other five still stuck, got another broken ratchet and breaker bar to replace...
Oh and found that the gas cap has gone MIA.
"Old Smokey'"
52vff,
Are the left side studs "left hand threads"?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Have not done anything to the 37 lately,its sitting so I can see if the old alternator was the cause of the battery drain.
Put some heat to it.
~Jim
I took my 51 four blocks down the street to the High School where we had a 25+ car, neighborhood show. I met some nice guys and saw some very nice rides.
~Jim
