5 members (66flea, 2-Ton, Jay R, TooMany2count, Nick in Manitou), 319 guests, and 7 robots.
Topics128,158
Posts1,057,025
Members48,460
Hi there
Just found this site ... very good ... and, I like all th' old trucks --- well, the old GM / Chevy trucks (and have two '53 International - R-110's 1/2 tons #1 with all Chevy Running gear (68 chevy 250 I-6 , p/g , with the IH Truck mounted
on a Chevy Frame. == #2 International with all stock IH gear). Still an OLD TRUCK ...
Then my car : 69 Chev Nova with the stock matching engine == 250 I-6 (155hp) , had a p/g ... just installed a B-W W/C T 5 ... with help from " Lugnutz" T 5 page. (working GREAT - by th' way).
Thanks for having me .
jim
Jim, welcome to the Stovebolt and all the madness you an stand...just kidding. We welcome you and everyone is willing to help. Post questions in the most appropriate forum and we will be glad to help out. Enjoy the journey and be sure to watch for other bolters from your area. They are definitely some AZ bolters here.
I see you have "met" lugnutz. I'm fortunate to have met him and we've visited each other on several occasiond/ Super nice guy!
That would be yes for Jay - aka - lugnutz.
I just installed a 93 GMC W/C T-5 into my 69 Nova , using alot of his info. I have posted over on his site ......... Really Good Info for Those type tranny's.
and, I see these guys are using that trans for their Trucks.
I can pass along a very good "item" for using your 'stock speedo head with an electric drive speedo (VSS). I am using my stock Nova dash speedometer by using the
" SPEEDHUT SpeedBox " unit to run my cable - drive speedo-head. I've got about 2500 miles plus , since my install .......
Both MPH & Trip Miles are working GREAT ( trip miles readings are spot-on correct. My miles per-hour readings are may-be 1 or 2 miles off). That's close for a 40 plus year old car .
Then, I have NOT even wired up the trans VSS sensor .......... they give you a GPS anntena ........ it's running working great & simple.
Thank for the Welcome
jim partridge
Welcome to the Stovebolt madness. There is no cure! I see you are into Binders. We have lots of IH fans here. As Alvin said, look over the site and post any questions in the most appropriate forum. A word of caution, limit your questions in the garage forums to pre 73 Chevy/GMC Trucks. Any questions relating to the Nova or the IH specific stuff are welcome in the “Greasy Spoon”. We are all happy to have you here and are more than willing to help out if needed. Again welcome. shake
Jim, Welcome to the 'bolt.
Please scroll through the various forums to see what they have to offer.
Make sure to check out the rules of the page as well.
Questions pertaining to your problem are welcome and will usually get answered quickly.
There are many "how I done it's" here as well that can be found using the search feature.
Another quality post.
Real Trucks Rattle
