2 members (Dave1234, 1 invisible), 64 guests, and 2 robots.
Topics128,208
Posts1,057,448
Members48,471
#1294329 01/10/2019 11:52 PM
Has anyone installed a classic replica radio and used a MP3 Player for music? If so where was the MP3 Player bought and what kind.
dougs #1294395 01/11/2019 3:49 PM
If you're talking about a radio with a 1/8" headphone jack style input, just about anything with a 1/8" headphone jack output should work using a male-to-male plug to connect the two.
If you're asking about hooking up with a USB and having the radio be able to communicate with the MP3 player and control it, then you'll need to check with the radio manufacturer and see what their compatibility is. I would venture a guess that Apple iPods and iPhones are likely to be compatible, and not a whole lot else, but I could be wrong and there could be more platforms supported.
dougs #1294754 01/13/2019 7:07 PM
You can add an FM Tuner and and auxiliary input to your AM radio. The Aurora FMC-2 FM Tuner is a small circuit board that you can add between your antenna and the AM radio's circuitry. You switch between the 3 modes by repeatedly turning the radio on & off.
See Radio Upgrades
