11 members (55shaker, Doug Boudreaux, Steveoreno, 1955 1 Series, Bill Trotter, dt235sd, Jethro in Va, 3B, Wingnut68, moparguy, Peggy M),
69
Mod | | | Forums66 Topics128,197 Posts1,057,400 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | Has anyone installed a classic replica radio and used a MP3 Player for music? If so where was the MP3 Player bought and what kind. | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | If you're talking about a radio with a 1/8" headphone jack style input, just about anything with a 1/8" headphone jack output should work using a male-to-male plug to connect the two.
If you're asking about hooking up with a USB and having the radio be able to communicate with the MP3 player and control it, then you'll need to check with the radio manufacturer and see what their compatibility is. I would venture a guess that Apple iPods and iPhones are likely to be compatible, and not a whole lot else, but I could be wrong and there could be more platforms supported. | | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | You can add an FM Tuner and and auxiliary input to your AM radio. The Aurora FMC-2 FM Tuner is a small circuit board that you can add between your antenna and the AM radio's circuitry. You switch between the 3 modes by repeatedly turning the radio on & off. See Radio Upgrades | | |
