6 members (TooMany2count, 78buckshot, Gdads51, KEVINSKI, dt235sd, 1 invisible), 161 guests, and 1 robot.
Topics128,081
Posts1,056,069
Members48,434
Can anyone identify this pickup bed for me? It's not mine, but a friend's. The hole on the right hand side looks like it's factory cut. Length of the bed is 7 1/2ft long. The rear bumper has one of the bumper bolts that is an oval shape (not pictured) instead of round. Is it Chevy/GMC? Thanks in advance JP
Fox Offline
1947-1948 3/4 ton chevy/gmc box. The hole is factory cut. It is for the gas tank that was under the bed on that side. Only 47/48 had this hole, after that the gas tank went in the cab.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Man, that was fast. The only pictures that I could find in the gallery had the gas tank fill tube on the right hand side of the cab. Didn't see any with the filer on the bed. Thanks!
Fox Offline
That’s the beauty of this site! You’re welcome, Jon.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
No real way to tell if it's Chevy or GMC. And not just the bed, it's half of the frame from a 3/4-ton. Should haul a good load.
Professional Novice
Yep, the only difference would be the tailgate with logo, which appears to be missing.
I THOUGHT it might be Chevy/GMC by looking at the shape of the uprights on the side of the bed and the tailgate hinges. But didn't know for sure. It's good to know the years and that it's a 3/4 ton bed. Thanks again JP
I see a lot of "bed trailers" around here. Are you going to practice your dent removal skills on that?
Another quality post.
Real Trucks Rattle
Those fenders are actually in pretty decent shape. No rust-thru's that I can tell. A little hammer and dolly work and they'd be ready for paint. wink
That front panel would be a PITA to straighten at the top though. eek
Left fender is worse than the right one. I figured a decent body man could fix the right one. Side panels are in good condition . Wooden floor is gone though. JP
