4 members (2-Ton, baldeagle, BC59, 1 invisible),
74
9
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12941 04/12/2004 1:11 PM | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | Does anyone know if a BW 4 speed can be converted to a 5 speed version without too many hassles?
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
#12942 04/13/2004 10:39 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | In which way are you referring to? Using the BW case from a 4 speed,, the answer is no, not at this time. You can swap in other 5 speed units with some mods.
#12943 04/16/2004 1:56 AM | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | I have one of the S-10 four speeds that I would convert to a five speed,if it were possible. I guess I will just use the four speed till I can find a five speed at a decent price.
