Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Guitplayer, Hush), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#12941 04/12/2004 1:11 PM
Does anyone know if a BW 4 speed can be converted to a 5 speed version without too many hassles?
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
#12942 04/13/2004 10:39 AM
In which way are you referring to?
Using the BW case from a 4 speed,, the answer is no, not at this time.
You can swap in other 5 speed units with some mods.
#12943 04/16/2004 1:56 AM
I have one of the S-10 four speeds that I would convert to a five speed,if it were possible. I guess I will just use the four speed till I can find a five speed at a decent price.
