7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I've got a '46 Panel with a SBC 350 and I hope someone else has done this before me. It's got the original radiator in it and I'm putting a 16" electric fan behind it. Has anyone built or know where I might find some kind of plans to build a shroud for it?
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | I recently put a 283/TH350 in my 46 and used the original radiator. Mine is working good so far but the hot weather has not hit yet. I put the electric fan in front and used it as a pusher, no fan on the engine. Where are you going to put the shroud? Will you use the electric along with the engine fan? . Rick | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | My mechanical fan was sitting too low and not performing well enough ... I have a 350 sbc, too ... but didn't need a shroud with the electric fan I put in my truck. [img] http://www.alanhorvath.com/54chevy/chevypics/rad_back_newold.jpg[/img] If you're using a 16-inch fan, I suggest you use Two Relays -- See Here I also believe in using a Fusible Link instead of a circuit breaker (and definitely NOT a fuse).
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I'll be doing just exactly what Alan did with his. A 16" Zirgo 2700CFM high on the radiator as a puller. I've only got 4" of clearance between the end of the water pump shaft/pully and the radiator. With the fan in place I'll have about 1" to 1 1/2" clearance. I've always heard you need a shroud to get the full use out of the fan. And I'm looking very hard at the two relay set up also. Thanks Alan and Rick
Alan I do have one question. Why did you or the PO put the alt. on the passenger side and the AC on the drivers. I'm looking at setting it up just the opposite. I'm not sure if it makes any difference or not maybe someone will answer that too.
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, David
The PO did that arrangement with the AC and Alt ... I believe the Alt is always on the pass-side on a 350, but I'm guessing he set it up that way because the hoses from the AC condenser are on the driver-side and it just made more sense.
I doubt it makes any difference at all ... I'm sure it's just a matter of what makes sense to your setup.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I modified my radiator support and radiator, fab'd a shroud and went with a 17" mechanical fan blade. My thoughts were it would be one less electrical maint.load to worry about. You can lower the radiator about 2" and move forward by drilling the spot welds off the rad side mounts.You can see here http://community.webshots.com/user/zeker6 that was my solution. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Try Chevy Duty,I bought a shroud for my 55 2nd from them.It works very good.I am running a 350 with the stock 55 radiator. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | From 1969 on, I believe, the alternator appeared on the passenger side of the engine. Up to 1968, it was on the driver's side. You could use the earlier brackets and mount the alternator on the driver's side, right above the power steering pump, but you'll have to use a short water pump. The later style uses the long water pump. Nice job on that 283. It appears that the top of the air filter comes up to about the top of the radiator. That's some excellent clearance below the hood. Looks to me like plenty of room for a roots blower.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | The 350 that I am using for my 46 has factory ac and this is how it came ( alt on passanger side ). I am leary about using an electric fan so I moved my rad to the outside of the rad frame and lengthened the frame by about 4 inches so i could drop the rad down. This is on a 76 frame. There are a few pics in the smothie folder. Hope this helps http://pg.photos.yahoo.com/ph/sublime589/album?.dir=d9d2&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/sublime589/my_photos | | |
