Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Otto Skorzeny, DoubleB, 55shaker, G508, Peggy M, 1 invisible), 157 guests, and 3 robots.
Topics128,283
Posts1,058,517
Members48,490
#1293525 01/04/2019 4:52 PM
I saw an ad for a 235 engine with a 6 digit number on the block. I can't find this number any where on the casting number lists on any of the sites. I've attached a photo.
thanks,
Joe
1946 Chevy 3/4 Ton Flatbed
Tearing her down
Story in the DITY Gallery
More images
343876 block casting code?
What is the Engine Serial Number, and the block date casting code?
http://www.1954advance-design.com/Web%20images/casting-code-photos/low-press-codes-ser-nums.html
Look to be a newer (194 /230 /250 292) engine from the bit in the photo.
BC
1960 C60 pasture art
Side motor mounts however my ‘62 235 had the drilled/tapped holes for the side mounts even though it had the front mount.
Looks like the bottom of a coil for an HEI that doesn't have the coil in the cap. Could it be a 230/250?
Tommy
59 apache 1/2t
261 short stepside
Here's the engine. I'm thinking a 250 from the valve cover with the 6 mounting bolts?
Tearing her down
More images
It can be a 194/230/250. we can't help without the rest of the numbers.
Fred
52 3600
69 C-10
Insomniac
Insomniac
1974 didn't have HEI. 1978 has HEI coil in cap. So should be 1975 - 1977 assuming distributor is original to engine.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
