| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | Has anyone tried replacing the vacuum shifter on the rear differentials with an electric solenoid? Is it worth attempting? How reliable are the vacuum shifters and the control valves? | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | What year/model are you asking about? Mike B  | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | I have no issues with the vacuum shift on my 58 2-ton. I have been driving it for 2 1/2 years. | | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | | | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | I'm just worried that the lines will inevitably start to leak. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They’re steel lines and short rubber hose. You can replace either if necessary | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Mines been great for over a year and a half. And that's with a temp repair in the middle. When I was attempting to diagnose it i found a rather large leaking area, fixed it with wrap and it's been good. A permanent repair is coming this winter I hope. Shouldn't be hard. 1/2" line from along frame from front to rear flex lines. It works so seamless and smooth I wouldn't change a thing. Like anything a little maintenance and it's good. | | | | | Joined: Nov 2000 Posts: 1,398 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,398 | When I restored my truck I don't even think I had to replace the steel lines. I cleaned them up and just replaced the rubber hoses. I also replaced the diaphragm on the rear. I was lucky at the time to find one sitting on a shelf, NOS. Anyway, although the truck doesn't see lot and lots of miles every year, I have had no issues with my two speed rear since I got it on the road in 2003.
| | | | | Joined: Nov 1995 Posts: 5,713 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,713 | Yeah, the only issue with Marlow's truck is with the Steering Wheel Actuator .... Needs a complete rework ...  FWIW, as long as you are messing with it anyway, remove the rubber diaphragm and give it a good soak in some silicon (dot 5 brake fluid worked for me) to rejuvenate it a little.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | DOT 5 (silicone) brake fluid has at least one serious disadvantage - paint contamination (be careful - be forewarned). | | | | | Joined: Nov 2000 Posts: 1,398 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,398 | | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Having used both types of shifters pretty extensively, the vacuum shift is far superior in my opinion. The shifts are smoother and there's a lot less to go wrong. When I drove a Freightliner with electric-shift rear ends, I always carried at least one spare electric actuator to assure I wouldn't get stranded somewhere waiting for parts. The motors, and especially the shift switches were really bad about failing with no warning. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Vacuum shifters exist in some yards.
Ed
| | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | Thanks for all the advice guys. I'll tear mine apart and try to fix it up. It will need all new lines and I don't know if the switch/valves are good yet. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | If the truck doesn't have one, it would be a good idea to add a vacuum reservoir tank. With a one way check valve between the engine and the reserve tank you'll have a couple of brake applications available, and/or smoother rear axle shifts. I like to use a recycled Freon gas tank. Most refrigeration shops will give you one (or several) since empties are usually discarded, not refilled. With some flat steel strap mountings, one or two of them fit very nicely inside a big truck frame rail. Jerry
| | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | If the truck doesn't have one, it would be a good idea to add a vacuum reservoir tank. With a one way check valve between the engine and the reserve tank you'll have a couple of brake applications available, and/or smoother rear axle shifts. I like to use a recycled Freon gas tank. Most refrigeration shops will give you one (or several) since empties are usually discarded, not refilled. With some flat steel strap mountings, one or two of them fit very nicely inside a big truck frame rail. Jerry Can you post some photos of this setup? | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | It's been 30-something years since I was involved in medium and heavy truck work. It's a pretty simple task to mount a reservoir tank or two inside a frame rail and run a vacuum line from the intake manifold to it. Then attach lines going to the brake booster and/or the axle shift system to the tank. Since the vacuum is trapped in the tank by the check valve, there's a reserve of vacuum available even if the engine stops. It's simple common sense that any plumber could figure out. On smaller trucks like a pickup or a 1 ton, a 3 foot length of 4" PVC drain pipe mounted under the cab with a couple of end caps glued on accomplishes the same sort of vacuum reserve. Jerry
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Hello everyone, I have the ashton 14 years and have had no problems with it's vac. system. because of where I live I have to use it right out of the stovebolt firehouse station 51. I agree with hotrod that the vacuum is smoother shifting. Shifting a vacuum shifter can be challenging at times. Like Billy I found a nos unit in the box some years ago and sucked it up just in case. Having a 51 GMC 350 and a 51 Chevy 6100 the gmc has the better setup in the vacuum valve and its mounted on the firewall. Chevy uses a linkage rod to go down to the inside of the frame rail. When I got the dump and once one humid summer since, it froze up and I couldn't actuate the shifter when I went to make a shift. Kroil and working the shifter slowly back and forth freed it up to the point of smooth shifts. | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | 51 Ashton, your Chev's is mounted on the frame rail? Mine is one the firewall like you note for the GMC, and my 48 to 51 Canadian Maintenance Manual shows it that way for both. Maybe another US / Canadian difference? | | |
