3 members (TUTS 59, WICruiser, 1 invisible),
125
Mod | | | Forums66 Topics128,090 Posts1,056,382 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | How much should the gas filler neck extend beyond the cab on a 1958 Chevrolet Apache 3100? | | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | I don't have the same truck as yours but the gas cap is only about 3/4 inch from the cab.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I always figured if it was out far enough the gas cap doesn't gouge the paint all is good.
Evan
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | There is a metal ring around the top of the filler neck. The rubber seal should be right below that ring leaving just the ring exposed. Mike B  | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Interesting replies to my question. I will pass this on to the shop performing the restoration work on our truck. All the ones I have seen pictures of on the internet, the cap is pretty close to the side of the cab, without coming in contact with the paint on the side of the cab.
John | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Yup, it's close to the body, but not so close you can't get your fingers under it. From a side view all you see is the grommet and cap. Mike B  | | |
