3 members (Hotrod Lincoln, homer52, Gray_Ghost), 120 guests, and 5 robots.
Topics128,109
Posts1,056,261
Members48,439
#1293131 01/01/2019 5:06 PM
How much should the gas filler neck extend beyond the cab on a 1958 Chevrolet Apache 3100?
raleigh58 #1293172 01/01/2019 11:21 PM
7
7 Offline
I don't have the same truck as yours but the gas cap is only about 3/4 inch from the cab.
raleigh58 #1293184 01/02/2019 12:57 AM
I always figured if it was out far enough the gas cap doesn't gouge the paint all is good.
Evan
There is a metal ring around the top of the filler neck. The rubber seal should be right below that ring leaving just the ring exposed.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
raleigh58 #1293295 01/02/2019 10:01 PM
Interesting replies to my question. I will pass this on to the shop performing the restoration work on our truck. All the ones I have seen pictures of on the internet, the cap is pretty close to the side of the cab, without coming in contact with the paint on the side of the cab.
Yup, it's close to the body, but not so close you can't get your fingers under it. From a side view all you see is the grommet and cap.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
