2 members (VicZ, oldsteve), 123 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#1292314 12/26/2018 2:24 PM
Hi guys, i have a 52 chevy 1 ton 3800 series, i want to use the tech tip and put a new rear on. they said i need a 68to72 chevy truck. my problem is i cannot find one. i live by phila. can anyone help
jimbo 24 #1292316 12/26/2018 2:32 PM
In my experience the 4.10 gears for the Eaton axle will also be found in other trucks. Perhaps many are in those 68 to 72 3/4 tons.... but I’m not so sure why that’s all anyone talks about when looking for the 4.10 gears.
Open your search for any truck with the same axle and check the ratios as you find them. Same goes for any axle/gears you find, check the ratio to be sure.
Also check the Tons of fun section sticky thread for ideas on swapping a more easily found 14 bolt axle into your truck.
1952 Chevrolet 3800 pickup
---All pictures---
jimbo 24 #1292326 12/26/2018 4:52 PM
While the 4.10 gears are easier. I did it. The 14 bolt will work best if you know what your doing.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
jimbo 24 #1292424 12/27/2018 2:49 PM
thanks guys
jimbo 24 #1292483 12/28/2018 12:35 AM
Grigg, one reason the 4.10 Eaton gears are so scarce is the fact that they were almost exclusively used in 3/4 ton trucks with automatic transmissions- - -the "Camper Special" pickup, and some Suburbans with 3/4 ton suspension. Another reason is that us 1/4 mile dirt track racers scoured the wrecking yards in the late 1970's looking for those rear ends to run in our race cars. The combination or a 1.88:1 Muncie 4 speed 2nd. gear and a 4.10 Eaton rear end was just right for running on a quarter mile round track.
jimbo 24 #1292496 12/28/2018 2:14 AM
So there it is.
Its Jerry's fault!
jimbo 24 #1292569 12/28/2018 5:04 PM
1985 Chevy Blazer rear end
I had 1953 model 3800 that I rebuilt a few years back. I went with a 1985 Chevy Blazer rear end. I had to weld on spring mounts and get a different u-join but it worked. I ended up with 4.10 gears. The old truck would top out at about 53 mph...can't imagine what it would have done with stock stump puller gears in it...
Just throwing out another option...
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
jimbo 24 #1292906 12/31/2018 5:43 AM
found one. Only about 1/2 mile from home. Imagine that!
