5 members (KEVINSKI, cmayna, TexasJim50, Gdads51, 1955 1 Series), 49 guests, and 0 robots.
Topics128,080
Posts1,055,946
Members48,430
#1290316 12/08/2018 4:26 PM
Hello everyone,
I just picked up an SM420 with the parking brake on the output shaft. My truck is a 1948 2 ton and currently has parking brakes on the rear axles. Will I need to change the drive shaft before the hanger bearing to fit the brake? Is it a good upgrade? Is the single band brake better than the two rear axle cable brakes?
Parking brake on transmission is much better in my experience, it has the axle gear ratio in its favor.
Pretty sure it’s a bolt in swap, nothing tricky or else to replace.
1952 Chevrolet 3800 pickup
---All pictures---
Excellent! Thank you!
Which parking brake does your SM420 transmission have, the dual shoe (used on the big trucks) or the single external band type (used on the 1/2 to 1 ton trucks)?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I’m curious to see a band type brake on an SM420, all I’ve seen are inner and outer shoe.
---All pictures---
Here is the picture of it. Picked it up off Craig's List for $100. Did I pay too much? It has a PTO too.
That’s about the going rate for a used one in working condition. PTO only has value if you need it.
---All pictures---
This is the transmission I have now.
Next time I'm in the shop I'll take a picture of one for you...it's sitting in the back on the floor!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I attached the drive line brake to the transmission and ran into a few problems. First, the pto levers are in the way of the brake so I would have to swap for a cable PTO. Second, I appear to be missing the correct yoke from the brake. Anyone know whats up here?
With the brake the yoke is a “flange yoke” with a 4 bolt flange, not the spline yoke you show.
Which means you need a “companion flange” which has internal splines and the same 4 bolt pattern to match yoke, and drum may be bolted in between.
Did you not have a complete transmission with the brake on it, if so it should have all you need to swap.
---All pictures---
It did not come with the flange yoke. frown
See if this helps...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Originally Posted by Mike B
[quote=Grigg]Next time I'm in the shop I'll take a picture of one for you...it's sitting in the back on the floor!
Mike B smile
Here's a picture of the SM-420 Band Brake...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
That helps quite a lot actually. Thank you. I will try looking for a yoke like that. It wont work on our 6100 ton but It should fit the 4400.
Thanks for the picture Mike.
Was that a small truck only for a year or two type thing, do you know the application?
---All pictures---
Mike B - Does Fitzy 440 need a piece of the contraption I have stored at JM's. As you may recall, I intend to do away with the brake on that SM420 and look for the pieces I need for a 1/2 ton (no brake) application.
If I had a picture of the piece (or description) in question I am headed out to the farm today and over the weekend.
~ HB
1962 Chevrolet C10
1962 Suburban
HB,
I don't remember what you have, but I think he needs the yoke that would be still attached to your drive shaft (this is assuming you have a Dual Shoe set-up, not the Band type).
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Drum is 8x2-1/2"...
1955-66 3/4 & 1 ton (36,38 C20 & C30)
1958-62 1-1/2 ton (Ser. 4 & 40)
1965-66 1-1/2 ton (Ser. 50)
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
