4 members (Joe H, 68ironhead, baldeagle, 78buckshot), 72 guests, and 5 robots.
Topics128,014
Posts1,055,329
Members48,419
#1292227 12/25/2018 2:41 AM
I have a 1956 Chevy 3/4 ton pickup. It runs great but when I drive it down the road it it will drift to one side or the other. It has a lot of play in the steering also.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
Bart #1292228 12/25/2018 2:55 AM
Check the Tech Tips under Suspension and Steering.🛠
Bart #1292284 12/25/2018 9:06 PM
If you have a Shop Manual, check in the Steering section for adjustments (and, to determine the amount a wear in critical parts).
This is an important adjustment:
This 1955nd manual technique should be the same for you '56. (steps 4-6)
It made a large improvement for wandering in '54 Suburban.
You can buy a "Steering Gear Scale" at Walmart (a small/light fish weighing spring-scale).
Also, play with the tire pressure:
- too high - you will wander too much
- too low - steering is difficult
Bart #1292322 12/26/2018 4:01 PM
Do what we all do. Start by assuming every steering component is worn to a degree. Then start checking and replacing as required. I seem to always end up replacing almost everything and still not satisfied then remind myself I'm comparing this 50 year old truck to my new truck. Don't expect any miracles.
