1 members (Steelonsteel),
113
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 140 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 140 | Hi - does anyone have pics of the petcock and feed line at the bottom of the in-cab fuel tank for the COE trucks?
Thx, Derek | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I am not near my COE but the setup is the same as for the standard cab. See Jim Carter (oldchevytrucks.com) and look at his part #s MEG108 for the shutoff valve and ME456 for the flex hose. Kent | | | | | Joined: Dec 2007 Posts: 140 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 140 | Thx Kent! I had bought https://www.classicparts.com/1949-53-Fuel-Tank-Petcock/productinfo/23%2D453/ but it doesn't appear the long end of the nipple will thread into the bottom of my tank? From what I can tell from the different sites, it should...I wonder if I need an intermediate fitting? | | | | | Joined: May 2015 Posts: 11,186 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,186 | The tank outlet threads are 1/8 inch national pipe (tapered). I understand some repop tanks don't have the correct threads. If you have a replacement tank that may be the problem.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | dhjmd, The intermediate fitting, as you refer to, is included with the classic parts petcock. That is the verticle pipe in the picture that is threaded into the valve and threads directly into the tank. If that doesn't fit then klhansen may be correct in that some repop tanks have metric pipe threads. If that is not the case then perhaps you could chase the tank threads with a 1/8 pipe thread tap. There are no other parts necessary to reproduce the factory fuel line out of the tank. Let us know how you fare. Kent | | | | | Joined: Dec 2007 Posts: 140 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 140 | Thx guys! My truck had the original tank that I was aware of. I got it done. I ended up rethreading the fitting and tapping my tank to match. Not ideal but did the job. Thx again all!
Derek | | |
