2 members (Woodcmiami, baldeagle), 93 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#129127 08/26/2004 1:38 AM
Apprentice
Apprentice
how about installing a 96 265chevy v-8 to an original 3-spd tranny in a 50 chevy 3100.
rrf
#129128 08/26/2004 5:56 PM
Sounds cool! I would rather have a LS1 with a 6 spd.
Joe K.
1963 Chevy Stepside
350 with 3 on the tree.
1960 Chevy Bel Air
35k original miles
1991 GMC Syclone #1557
1992 GMC Typhoon #0261
#129129 09/13/2004 2:15 PM
How are you going to mate up the original 3 speed to the 265? Are there adapter plates available? You know, Muncies are plentiful and cheap, you could easily stick a 4-speed on the back of that motor. Just an idea.
What's the 265 out of that you want to transplant?
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#129130 09/13/2004 4:30 PM
It would probably be a lot of work to adapt the old transmission to the new engine. If you swap transmissions, you're going to have to replace most of the driveline, as your truck should have the torque tube rearend, unless someone else has already replaced it.
1954 GMC De Luxe COE
#129131 09/16/2004 2:09 AM
I gave you this info awhile back in the engine and driveline forum. and dind't get a response from you web page . Maybe you didn't see it. I hope it will help you.
