| | | Forums66 Topics128,134 Posts1,056,403 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 663 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 663 | Are the Housings different or the same on 216 and 235 distributor? Wanting to use a 216 Housing (Delco-Remy Tag) with my 235 "guts". Will this work? Thank you.
1950 Chevy 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that all 47-53 216 distributor housings are the same. There were different sizes of 235 housings 1941-1962.
There are members who will correct the above, if necessary, and members who should know any changes/different in guts. | | | | | Joined: Feb 2004 Posts: 29,814 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,814 | check the distance from the top of the distributor housing to the tip of the rotor. I believe there's a difference in height when the tall cap and rotor is used with a dizzy intended for the short rotor which can cause a mismatch when distributor parts are swapped around. Jerry
