9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53), 236 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
Are the Housings different or the same on 216 and 235 distributor?
Wanting to use a 216 Housing (Delco-Remy Tag) with my 235 "guts". Will this work?
Thank you.
1950 Chevy 3100
I think that all 47-53 216 distributor housings are the same.
There were different sizes of 235 housings 1941-1962.
There are members who will correct the above, if necessary, and members who should know any changes/different in guts.
check the distance from the top of the distributor housing to the tip of the rotor. I believe there's a difference in height when the tall cap and rotor is used with a dizzy intended for the short rotor which can cause a mismatch when distributor parts are swapped around.
