3 members (BC59, cmayna, Peggy M), 144 guests, and 2 robots.
Topics128,095
Posts1,056,475
Members48,444
I've got a new radiator and need to plug the holes for the automatic trans lines in the bottom of the radiator. I'n mot sure what to use to plug these. A NPT pipe plug starts to go in, but I don't want to force anything. I think it might be a flare fitting? I dunno.
3B Offline
Hy Just Mark, The photo seems to show an inverted flare fitting, could be 1/4" or larger, it might be a bit of a search to find an inverted flare plug. First you will have to establish what size tubing and nut fits that hole, inverted flare is the fitting used on the fuel system on our trucks, hope that helps.
If you don't need the cooler, just leave them open, nothing will leak out.
Hmmmm, thanks guys. An easy check would be to put some water in and see what happens.
Moderator, Electrical Bay
Most of those come with a little plastic plug and that's all you need. As Joe said, nothing will leak out. If it did, water would be circulating in your auto trans and that would be a monumental problem.
~ Jon
Just Mark, the transmission cooler on the bottom of your radiator does not have coolant flowing through it. You can safely leave it open.🛠
Sweet. I put a half gallon or so of water in and wadda ya know, nothing came out. Easy problem solved. On to the next hurdle.
Thanks!!
If you ever wanted to use it then keeping it plugged and clean is a good idea.
I'd guess it's 3/8" inverted flare. Plugs are available, try local auto parts store and ask for Weatherhead or Eaton part number 131-6
•1952 Chevrolet 3800 pickup
---All pictures---
Good info, thanks.
Just leave them open- - - -the mud wasps will plug them up in a matter of weeks- - - - -maybe even days!
Beat me to it Jerry!
Great minds,
need not apply. smile
7
7 Offline
We are 'gonna have to wait for spring next year for the insects, it's cold now in this neck of the woods. If it were mine I would plug them with the correct inverted flare plug. I can't remember if you have a NAPA store in Durand but you should have no trouble finding the right size.
It's currently collecting dust next to my desk. I'm just relieved to know nothing is gonna leak out...hopefully.
You could cut a piece of Aluminum Foil tape (the kind used on AC ducts) to cover the hols. It will last as long as your radiator and can be painted (if you paint the radiator). You can get it at any hardware store, Lowes, Home Depot or Walmart.
Harold
Harold
That aluminum foil tape roll makes for an awesome cup holder. Way cooler than a roll of plain old duct tape.
You will have plenty of the roll left after you tape your holes up.
I got mine at the local O'Reilly's. I hope to install the new radiator (and trans cooler plugs) this spring. I did a quick test fit and the plugs seem to fit, but I did notice that they are 131-5, not 131-6. I'm hoping that since they are just there to keep dirt out, they'll still work.
Mike
1953 3100
The Gray Ghost
My Project journal
The -5 or -6 number indicates tubing outside diameter in 16th's. of an inch. Since most cooler lines are 5/16" diameter, the -5 plug is probably the correct one.
And I was thinking most were 3/8", thus the -6 part number earlier. Might be a little truck/car difference and I'm more familiar with full size stuff.
So long as it fits well you have the right plug..
---All pictures---
