| | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12905 05/05/2004 3:55 AM | Joined: May 2004 Posts: 67 'Bolter | | 'Bolter Joined: May 2004 Posts: 67 | Has any one installed a SM 420 transmission in a short wheel base pick up such as a 1959 Chevy. If so what did you do about the drive shaft. I've got several SM 420's to pick from. Some with the four bolt flat universal set up with the brake band and others with the u-bolt universal joint hook up. Will I have to put in a hanger bearing? Thanks | | |
#12906 05/05/2004 5:08 AM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Sorry I can't help. I installed mine in a long bed (68), so I did have to install the carrier bearing and make my own bracket for it. You will love it when your done. The pulling power is really impressive. Good luck!
35 + years of rollin' steel!
#12907 05/05/2004 9:27 AM | Joined: Apr 2004 Posts: 21 New Guy | | New Guy Joined: Apr 2004 Posts: 21 | My '59 1/2 ton came equipped with a SM420 4-speed. It has a one piece shaft and the emergency brake is the dash mounted type. I guess a 4 speed was available option. Mine is a deluxe cab fleetside, short wheelbase, with all the chrome, but it orginally had the standard heater and no radio. Someday must have ordered it that way.
Glen E.
#12908 05/05/2004 6:44 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Mule, I had tranny trouble in my 55 first series, so I put in an SM420. You may know this, but Napa and probably others can give you any combination of u-joints....big to little, little to big, etc. I went to a junk yard that puts all there used drive shafts in a bus for people like us to dig thru. Just pick the right length. It is easy to pick the right length once you get the tranny in. The length doesn't have to be perfect either. Hope this helps - Scott
55 1st Chev.
#12909 05/06/2004 1:58 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Yes, as you said in your private email, The splined ujointed shaft slides in and out of the splines in the rearend. - Scott
55 1st Chev.
