1 members (Chip O), 77 guests, and 6 robots.
Topics128,181
Posts1,057,189
Members48,465
Has any one installed a SM 420 transmission in a short wheel base pick up such as a 1959 Chevy. If so what did you do about the drive shaft. I've got several SM 420's to pick from. Some with the four bolt flat universal set up with the brake band and others with the u-bolt universal joint hook up. Will I have to put in a hanger bearing? Thanks
Pal Offline
Sorry I can't help. I installed mine in a long bed (68), so I did have to install the carrier bearing and make my own bracket for it. You will love it when your done. The pulling power is really impressive. Good luck!
35 + years of rollin' steel!
My '59 1/2 ton came equipped with a SM420 4-speed. It has a one piece shaft and the emergency brake is the dash mounted type. I guess a 4 speed was available option. Mine is a deluxe cab fleetside, short wheelbase, with all the chrome, but it orginally had the standard heater and no radio. Someday must have ordered it that way.
Glen E.
Mule,
I had tranny trouble in my 55 first series, so I put in an SM420. You may know this, but Napa and probably others can give you any combination of u-joints....big to little, little to big, etc.
I went to a junk yard that puts all there used drive shafts in a bus for people like us to dig thru. Just pick the right length. It is easy to pick the right length once you get the tranny in. The length doesn't have to be perfect either. Hope this helps - Scott
55 1st Chev.
Yes, as you said in your private email, The splined ujointed shaft slides in and out of the splines in the rearend. - Scott
55 1st Chev.
