4 members (Samantha, Hanks custodian, Hotrod Lincoln, Otto Skorzeny), 138 guests, and 1 robot.
Topics128,081
Posts1,056,074
Members48,434
Once in awhile I check the speedometer reading of my my truck, '65 m00stang & VW camper, using my favorite speedometer phone app "Speedbox". If you haven't tried it yet, give it a hello.
Which is your favorite, if you have one?
Craig
I like DigiHUD
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
I just use my Garmin GPS I usually have mounted in my company car. I’ll give “Speedbox” a try. Had never heard about it.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
DigiHUD for me too. You can set it any way you want - digital, analog. Simple, and super visible.
And did I mention that it's FREE?
1951 Chevy Panel Truck
I use "waze" It's ok. Try it, you might like it.
Steve
I find a variety of different speedometer HUD's such as XHud, ProHud, but not DigiHUD by name. Who's the mfg?
Craig
I also use my ancient old Garmin because it also gives the posted speed limit and I'm too cheap to buy a new one. On most the street rods we do we use the gps speedometer because it's dead accurate no matter what gear changes are made or tire size used. There are very few gps "dead" spots anymore.
Evan
Here's the link to get DigiHUD:
https://play.google.com/store/apps/details?id=org.mrchops.android.digihud&hl=en
Good point on the Garmin - it displays posted speed limits for the road you're on.
7
7 Offline
I had the wife follow me in our modern(2000) truck when I made the loaded maiden voyage, topped out against the governor on the way home-47mph. I don't have a cigar lighter in the 5700 yet so I hav'nt thought about the garmin. I guess it could run on battery long enough for a test.
78buckshot,
Do you have a cel phone? You really shouldn't need a ciggy lighter in your project rig for this. If your garmin can run without being plugged in all the time, then just do it.
Also, aren't we familiar enough with our local street speed limits? Really need a Garmin to tell you? LOL
Craig
V
V Offline
I removed the radio block off plate & made up a plate to mount my Garmin in. The speedo function is accurate and I use the Eco Route feature to track fuel use and MPG.
Visability in bright sun is usable, not as good as the OEM speedo but passable.
Pic
Pic
My truck sees long trips on a regular basis, often 4 or 5 hours from home. I'm in "unfamiliar" territory quite often and tend to miss speed limit signs. My speedometer works and is dead on, but it's nice to be notified by my GPS when I'm exceeding the speed limit (before I'm notified by a cop).
I had a speedometer app on my phone that would also give 1/8th and 1/4 mile times. It was hands free, automatic and accurate, but pointless when running a stock 69 year old 216.
