2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#129027 08/31/2004 11:46 PM
That was one of Amy's requests... suicide doors. So I orderd a set of hinges from Suicidedoors.com and went to town!
Some cutting here, welding there, grinding everywhere and the driver side is swinging fully. It opens smooth and closes perfect. Window even opens. Further, there was no need to cut any of the door post off as was described in the
"Truck Builder (November/December 2002 issue)" suicide door install.
Check out pics at: Http://www.streetsourcemag.com/Profile.aspx?Home=true&ProfileID=20110
I've got more pics of the actual install, but took them on the SLR - need to be developed.
- Ryan
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
#129028 09/01/2004 12:40 AM
Anonymous
Unregistered
Anonymous
Unregistered
Nice job Ryan! That door handle in the original location will throw some for a loop. Now you have to chop that top!.
#129029 09/01/2004 1:38 AM
Howdy Neighbor--long time no see!
Boy those doors are lookin' fine! Last time I saw them they we're just mocked up. Great work. Hope your new job isn't taking you away from this project too much (maybe it allows you to justify trips to Spokane for parts!)
I'll give you a shout soon-
#129030 09/01/2004 5:15 PM
As for the handle - it will be gone soon enough - it was just left there to help me lift those HEAVY (had to brace the inside of the door, adding even more weight :mad: ) doors up and onto the hinges.
No chop top for now - maybe if and when I do a stock floor body drop and bags.
Phil - stop by anytime..... I don't have an office at the WSU anymore, so I'm working from home until the 17th.
- Ryan
59 Apache Step
78 El Camino
#129031 09/01/2004 7:35 PM
"working" might mean shaving the door handles! I'll try to swing by soon
#129032 09/01/2004 10:47 PM
Socket Breaker
Socket Breaker
Cool dood... I don't think that'd look right on my '65 but it looks good on yours. smile
-W
#129033 09/02/2004 3:31 AM
And the advantage is.............?????????????? :confused:
#129034 09/02/2004 7:57 PM
Isn't the advantage obvious? I can open my doors backwards and won't need a handle to do so! grin
Same advantage as shaving the emblems, shaving the dash, making a frame, using seats from a F$%^, a rear end from a Nova, front from some fabrication company, Boyd wheels, and painting the whole thing bright [censored] orange!
It's called custom. And it suits our needs perfectly.
- Ryan
59 Apache Step
78 El Camino
#129035 09/09/2004 12:45 PM
Looking good , yall have done a great job so far!
#129036 09/09/2004 2:11 PM
Prof Ryan: Where did you get your gas tank and also are you painting your interior the same as the outside? Pops
popcorn The Truth is Out There (Looking good son and I love looking at pictures)
#129037 09/09/2004 11:32 PM
The tank is from Summit - 16 gallon cell with foam and 90 ohm sending unit.
We doing the interior the same as the outside, except that I will be doing a console, door panels, headliner. Probably a similar tweed as to what is in the El Camino interior. Gray carpet.
- Ryan
59 Apache Step
78 El Camino
