5 members (Otto Skorzeny, klhansen, MNSmith, pdlightning, 1 invisible), 60 guests, and 5 robots.
Topics128,022
Posts1,055,373
Members48,420
#1290000 12/05/2018 10:23 PM
I'm really getting tired of fooling with this old truck. I feel like I have a $15,000 piece of yard art. Went to rebuild the Rochester 1 barrel carb today and run into another problem. Went to put carb back together after taking it apart and cleaning it and one of the screws would not go back into the butterfly on the throttle body. Somehow between the time I took it out and cleaned the carb and went to put it back in, the threads got screwed up. I don't have a clue how that happened. Anyway, after two hours of fiddling around with it, I ended up losing the screw. Now I have a worthless carburetor and a truck that won't run until I get another carb. Some days I wish I could just sell the thing and get my money back.
Former Workshop Owner
Hang in there. I'll take a look and see If I have an old junk carb I can rob it from.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Feel for ya bro. Turn the light out in the garage and go into the house, a new day tomorrow with a fresh state of mind.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Moderator, Electrical Bay
Sometimes those threads will be ok but once the screws are removed...they don't want to go back in because they've been buggered a bit on the end. I have new screws for the Rochesters. If you need one, just let me know. It might be ok.
~ Jon
Another thing you can try, Darrell is to take the recalcitrant screw and very carefully shave the tip of it with a tiny file or fine sandpaper at a slight bevel. It isn't fun work, but I've gotten several to go back in by doing this over the years.
~ Jon
Thanks Jon. I will be needing a new one. While I was trying to put the one back in that I could not get started, I dropped it and I haven't been able to find it. These are the smaller brass screws on the butterfly in the throttle body, not the larger ones in the choke butterfly. How much do you need for one?
Don't get discouraged. I've felt that way before when I first got my truck. Made some mistakes. There is a wealth of knowledge on this site and many people are available to help you. I have learned so much talking with people here. I'm glad that I never got rid of my truck. Hang in there.
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
I did the same thing i think those screws may have been bent or peened on the ends so they dont come out of the shaft and when you unscrewxthem it messes up the end threads.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Just send me a PM with your postal address. Smaller diameter and a finer thread with a head about 3/16" in diameter as I recall. I'll get my box of Rochester parts out of the attic and send one off in tomorrow's post. Do you only need one?
~ Jon
The lesson to be learned here is don't try to remove throttle plates from the shaft unless there's a good reason to do so. If you do, drill the peened end of the screw away and use new screws to reinstall the throttle plates. You can loosen the screws slightly and tap on the plates to make sure they're centered in the bore, then retighten the screws but don't dismantle things all the way unless you've got new screws on hand.
We all have probably felt that way at one time or another. Lord knows I have. I agree with sstock, turn the light out and take a break.
Professional Novice
Beer me!
That's what I do when I get in a pickle.
Just as when life hands you lemons, you make lemonade, when I get in a pickle, I get pickled. Well a little bit anyway.
Garth Brooks has the right idea!
Darrell,
One day at a time! If you ever want to know all the crap that happened to me just ask! I had a years worth of experience that was not fun. Once you are up and running, it will all be worth it! In the mean time, Carl can you pass me a beer?
Chris
V
VEW Offline
V Offline
Yeah, we all been there! What I do in that case.....after working for hours and hours and hours on something and not only am I not making progress, but actually going backwards, is go over and get my BFH, raise it high over my head, start approaching the truck with it, and then the truck says, "Please don't,..I didn't do anything wrong".
Then I go over and turn out the lights and grab a beer (or another one)!
Remember, the joy is in the journey...the joy is in the journey.... smile
~ Victor
1957 3100 - moved on
THIS!
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Riding in the Passing Lane
If you can't get a screw to work in it I have an extra throttle body for a 216 Roch. model B. Ive even put a sheet metal screw in one before. Worked fine.
George
1972 Chevy c10 Cheyenne Super
Beerthirty time. One day, and one thorough step at a time.
1946 GMC Project
"Back-in-the-day Restore"
I twisted the heads right off two screws because I didn't know they were peened on the end. Sent the carb off for a rebuild and they repaired everything. Lesson learned.
Tip of the day: Small parts are seldom lost if . . . . you sit in the bathtub to work. (Make sure to put the plug in the drain first!) eeeek
Like VEW says it is the journey, but the road is not a super highway. On my panel, the journey is about 16 years long so far, this includes 3 body shops who decided they were only kidding when they agreed to fix things, and a lot of money. Just keep driving on.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Hang in there. I am still trying to figure out my MPG drop.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I guess my mistake was watching a youtube video by Mike's Carburetors walking through how to rebuild a Rochester 1 Barrel Carb. He made the statement that he didn't consider a carburetor rebuilt unless you take out the butterflies. I thought once about not doing it, but then did. I thought I was ok, because the screws came out ok. All but one went back in with no problem. Lesson learned is not do that again.
Send your carb to Carolina Carburetor. http://www.mycarburetordoctor.com/ 910-762-4695
Butch is the very best at rebuilding carbs. He rebuilt the carb on my truck, it starts and runs very well as long as I remember to turn the kill switch off! smile After rebuild, he runs the carb on a test bench that assures everything is 100%.
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
I'll second that recommendation for Butch at Carolina Carburetor. He rebuilt my Rochester & did it quickly at a good price.
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
You could just attend the ODSS homecoming, bring a rebuild kit, and have guys like Jerry teach you!
Chris
Q
Q Offline
There is an automotive shop here in town that has a sign that reads, "thanks to YouTube mechanics,our shop is always full" being an automotive/heavy duty tech my self, i do ,at times get the" but i saw a guy on you tube that ......."( fill in the blank however you want) . Now, a small precent of them do know what they are talking about, the rest know just enough to be dangerous and leaving one scratching his head asking "really?"
Dad said it very well back in the 1950's- - - - -"Getting repair work at a service station is like getting brain surgery at a drug store!" I stay busy in nine southeastern states now, investigating claims of improper repair work and subsequent damage to people's cars done by places like Firestone, Goodyear, and other tire stores, oil change and "quick service" businesses. On the other side of the coin, dealer service departments are often in cahoots with the sales end of the business- - - -as soon as a car is paid for and/or out of warranty, it's time to sell the customer another new car. The prices to keep the "old" one on the road suddenly gets VERY expensive! A good independent shop with a long history of providing good service at reasonable cost is hard to find, but doing business with those places has always been the best choice.
I took my F250 to a local shop known for good work on Powerstrokes to get some work done that I didn't have the capability to do myself.
In some discussions with the shop owner, he made a comment that the local Ford Dealer was his best source of work. Customers came to him after they either got an enormous repair quote or worse, had a "repair" done at the dealership that didn't fix their problem.
