3 members (RLB, papas52, 1 invisible), 91 guests, and 3 robots.
Topics128,154
Posts1,056,851
Members48,456
Junior Member
Junior Member
I was wondering if any fo you guys have used a stock '60 speedo in with a th 400.. the cable I remove from the '85 has a different end on it and will not install into the '60 housing.. Any ideas on this problem .. do older chev cables work?? like in the 60's or 70's?? I really like the old cluster I have it all reapainted and the outer trim polished like mirror.. If I cannot find a cable that will work are there aftermarket guages out there that will accept the '85 speedo cable??thank you
If the speedometer is out, take it down to local parts house and start looking at cables. I had no problem finding a cable for my '37 gauge and Turbo 350 transmission. Joe
Z
Z Offline
i know that the dash panel is different,but the powerglide cable on my 64 hooked right up to my turbo 400.
Junior Member
Junior Member
Thanks alot guys ~ ! I have hope now!
