Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1289134 11/28/2018 11:41 PM
Will 1954 water pump from a Belair fit in a 1953 1/2 ton with a 54 235 engine? I have a 53 1/2 ton and installed what I thought was 55 235 engine. Minimal clearance between fan and radiator. Hit a bump and fan tip cut into radiator. Unable to locate or see casting number on block but another number behind distributor ends " 54Z " so assuming I have a 54..Is there a difference between a car and truck water pump? THanks, Scott
scottss60 #1289135 11/28/2018 11:44 PM
The pump needs to be modified by pushing the fan hub back with a hydraulic press and cutting the shaft off a little. Some of the resto-ripoff places sell modified pumps for outrageous prices to people who can't do the press job themselves.
Once you get the fan and pulley pushed back to clear the radiator, you'll find that the fan will try to hit the harmonic balancer and it will be located too low to cool the engine properly. The fix is to purchase a pump relocation plate that allows the 54 and earlier water pump to be used on the post-55 block. That will put the fan in the proper location to cool properly, and fit far enough back to stay out of the radiator.
scottss60 #1289136 11/28/2018 11:48 PM
http://www.1954advance-design.com/chev-specs/1954-c-ser.jpg
54Z was a car 235, but the water pump should have been the same as on a 54 truck.
http://chevy.oldcarmanualproject.com/parts/1929_54/119.htm
scottss60 #1289138 11/29/2018 12:08 AM
If your engine has the high-mount water pump, chances are you've got bad motor mounts that have let the engine slip forward and take up all the fan clearance. I was giving information about the later model 55 engine with the water pump that fits into a hole in the front of the block.
scottss60 #1289666 12/02/2018 7:16 PM
pre68Dave do you have an adapter for my pump referenced above?
thanks, Scott
scottss60 #1289701 12/03/2018 1:13 AM
