1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Will 1954 water pump from a Belair fit in a 1953 1/2 ton with a 54 235 engine? I have a 53 1/2 ton and installed what I thought was 55 235 engine. Minimal clearance between fan and radiator. Hit a bump and fan tip cut into radiator. Unable to locate or see casting number on block but another number behind distributor ends " 54Z " so assuming I have a 54..Is there a difference between a car and truck water pump? THanks, Scott | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | The pump needs to be modified by pushing the fan hub back with a hydraulic press and cutting the shaft off a little. Some of the resto-ripoff places sell modified pumps for outrageous prices to people who can't do the press job themselves.
Once you get the fan and pulley pushed back to clear the radiator, you'll find that the fan will try to hit the harmonic balancer and it will be located too low to cool the engine properly. The fix is to purchase a pump relocation plate that allows the 54 and earlier water pump to be used on the post-55 block. That will put the fan in the proper location to cool properly, and fit far enough back to stay out of the radiator. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | If your engine has the high-mount water pump, chances are you've got bad motor mounts that have let the engine slip forward and take up all the fan clearance. I was giving information about the later model 55 engine with the water pump that fits into a hole in the front of the block. Jerry
| | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | pre68Dave do you have an adapter for my pump referenced above? thanks, Scott | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
