| | | Forums66 Topics128,129 Posts1,056,695 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 25 Junior Member | | Junior Member Joined: Apr 2003 Posts: 25 | I was wondering if any fo you guys have used a stock '60 speedo in with a th 400.. the cable I remove from the '85 has a different end on it and will not install into the '60 housing.. Any ideas on this problem .. do older chev cables work?? like in the 60's or 70's?? I really like the old cluster I have it all reapainted and the outer trim polished like mirror.. If I cannot find a cable that will work are there aftermarket guages out there that will accept the '85 speedo cable??thank you | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | If the speedometer is out, take it down to local parts house and start looking at cables. I had no problem finding a cable for my '37 gauge and Turbo 350 transmission. Joe | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i know that the dash panel is different,but the powerglide cable on my 64 hooked right up to my turbo 400. | | | | | Joined: Apr 2003 Posts: 25 Junior Member | | Junior Member Joined: Apr 2003 Posts: 25 | Thanks alot guys ~ ! I have hope now! | | |
