3 members (Otto Skorzeny, mason86, Gray_Ghost), 110 guests, and 2 robots.
Topics128,069
Posts1,055,890
Members48,428
#12894 12/13/2003 5:31 AM
I bought a vintage 3spd OD off ebay which is complete and in good shape except it didn't come with a yoke. I still have the original non-OD 3spd in the truck which I could take the yoke from. Does anybody know if it should swap in ? also, is there anything that actually holds the yoke onto the tranny ie: a clip etc, or does it just slide on the spline with the universal joint/driveshaft length keeping it trapped ?
:confused:
#12895 12/13/2003 6:27 AM
It slides in on the splines and is held in with a bolt in the center .
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#12896 12/13/2003 4:17 PM
That's what I expected, but the end of the output shaft of the tranny is not threaded and only has a
small hole or dimple really that probably was left over from it's manufacture. I suppose I could drill & tap it. The truck is an open driveline 3/4 ton by the way.
