6 members (greenie-reddy, FAST55, MRMEROTH11, Otto Skorzeny, 1955 1 Series, Hotrod Lincoln), 107 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1289377 11/30/2018 4:35 PM
V
V Offline
197? K5 chassis, 454 V8, the TH350 has _zero_ engine braking in any gear, my Son thinks this is normal, I know it is not and is dangerous on a 4X4 that goes down some terribly steep grades .
Where should we begin looking ? .
TIA,
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
H Online: Content
Is the torque converter original equipment, or has some sort of high stall speed unit been installed? High-stall converters have a tendency to freewheel in a coasting situation. Also you might check for a worn kickdown band.
