Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (NJC), 47 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#128875 02/01/2003 5:14 AM
Junior Member
Junior Member
I am at a point where I have to decide what to do with my windshield...I have a 51, 3100 1/2 ton [chevy of course] and can't decide if I should cut out the post and install a 2 piece butt joint windshield, or keep the post and stay stock.
I already have the butt glass, but where do I get the rubber seal? is the butt glass more likley to leak?
I would welcome your opinions on this .
Thanks Jerry :confused:
#128876 02/01/2003 5:35 AM
Anonymous
Unregistered
Anonymous
Unregistered
Jerry, it's your truck - you bought the butt glass for a reason didn't you? If you cut the divider out, save the parts for installation later if you decide to change your mind. Seems like the rubber is going to be pretty much a guessing game, I would go to a glass shop that does custom work and see what they say. I worked at a motor home dealership many moons ago and they had a huge inventory of glass installation rubber profiles. We could fit glass into anything! Good luck.
#128877 02/01/2003 6:39 AM
Jerry, I had a v butted windshield installed in my truck and they just used the stock windshield rubber and cut out the middle piece. The glass guy said he does it all the time. Good luck. wink
#128878 02/03/2003 3:38 AM
I cut out the center in my '40 and plan to do the same in my '50. The only drawback I can see is you can't hit the silicone with a high pressure sprayer. It'll blow it out...otherwise I like it.
#128879 02/04/2003 8:45 PM
seox,
Steele Rubber
They have the rubber gasket made w/o the center bar.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
