0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
Stovebolt Photo Moderator
Good Morning and Happy Friday,
A close friend and fellow wrencher is "borrowing" this piece for his rebuild. So I have no choice but to find another one.......for my eventual rebuild.
This one is from a 1958 (I believe) 261. Looks like an oil distribution fitting that lubricates the timing gears. It screws directly into the plate, and then bolts to the block as shown. A source for a new one would be appreciated. My "friend" will pay dearly. DAVE 261 !!!!
Hopefully this link works:
[img]https://photos.app.goo.gl/XznwmqsHtcSaLHh48[/img]
Thanks, Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
Nozzle, timing gear oil is correct. Some plates I believe this is a tube pressed or welded in, not threaded.
Used is probably where you’ll find one.
Part number for threaded type with 1/8” nozzle is 3690722
•1952 Chevrolet 3800 pickup
---All pictures---
Go get him joe!
This thread has good timing, this nozzle needs to be inspected and cleaned, on the 235 I have the nozzle is pressed in and flanged over on the inside of the plate. It was loose and the nozzle was pointing away from the gear set. I clocked it to point to the gear set and took a punch and put some stake marks on the back to tighten it up.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
A link to a few photos: https://photos.app.goo.gl/rwnBAvAWFckJTErs2
Great looking truck for the industrial thinking guys like me.
thank u.
Ok, somebody clue me in on what wrenchguy’s post has to do with this thread?
Sir Searchalot
Sir Searchalot
Nothing. He just thought he was in another thread I guess....or it's Forest Gump.
Cept, the yellow block looks really nice though.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
I did see a 235 the way you (SSTOCK) describe it, the nozzle is pressed in and flanged over as you say. I imagine it could be trouble if it gets clogged.
