0 members (), 116 guests, and 0 robots.
Topics128,127
Posts1,056,679
Members48,452
#1288348 11/22/2018 12:05 AM
Does anyone have information about old chevy trucks that have been used in the Navy?
I am looking at a truck that has the plate attached to it - see picture.
The information I can make out in the picture supports that is it a '52 3100 with a 216 in it (at least at one point).
Were these trucks a particular color? Is there any additional value to them?
Just trying to learn a bit more about this truck.
Thanks!
I have an I.D. plate exactly like that off a truck I used to own.
TC Lederman has a picture of mine.
I cannot find the photos of military ID plates.
I'll keep looking.
Sorry.
I might have found the plate - is it the one that is attached below?
Sure looks like the same kind of plate.
Anything special about these trucks that makes them identifiable?
Or just any truck that came off the assembly line and was subsequently purchased by the Navy?
Just curious.
Just curious.
Military vehicles were typically found to be very spartan with few options other than items would increase payload, ground clearance, or other mechanical/electrical systems. Old military vehicles have some following with the best examples being fully restored to their original build sheet. Colors varied through the years, I am sure there are some remnant painted areas on your truck. Sounds cool!
Lots more pictures
Paul has it correct, they were generally bare bones vehicles. If you look at the ID tag that Tim has posted, the contract number begins with DA. Military tactical (and commercial design) vehicles were purchased under contracts negotiated by the Department of the Army Tank and Automotive Command in Warren, Michigan. Agencies would submit their requirements and specifications to them and be included in established orders. Navy vehicles were painted navy gray up until the mid 80's when the standard colors were changed to white.
Fred
