1 members (Guitplayer), 104 guests, and 2 robots.
Topics128,149
Posts1,056,818
Members48,456
Does anybody know which vehicle these rims fit?
10 hole rim
http://www.mindspring.com/~lc_controls/images/20180110_113612-c.jpg
Stamped on rim: Accuride 27403
From Google search: OEM# 27403 Rim Size: 22.50 X 7.50 Bolt Pattern: 10 Hole on 11.25" Bolt Circle, 8.72" bore Mounting Type: Stud Piloted Dual Offset: 6.44" Material: Steel Number of Hand Holes: 2 Recommended Valve: TR500 Approx. Wt. (lbs): 73 Capacity: 6610 lbs. at 120 PSI.
Came with 9R-22.5 tire mounted on it.
There are lots and lots of trucks with that bolt pattern. Mostly larger or newer than what we usually talk about here.
•1952 Chevrolet 3800 pickup
---All pictures---
I thought most newer trucks with that 10 hole bolt pattern used the 11R or 12Rx22.5 size tires, which I don't think will fit these rims?
3B Offline
Hy Icc123, You are correct 7.50" wide rims are too narrow according to the tire manufacturers to mount 11R tires, I believe a 10R is the widest tire the manufacturers recommend for a 7.50 wide wheel. Wheels with that mounting pattern could be used on lighter trucks than the class eight trucks which use 8.25" wide wheels and mount 11R tires to, hope that clarifies.
The standard of the industry is 8.25x22.5 wheels with 295 75R25 or 275 80 R22.5 tires. The 7.50 x 22.5 would be the wheel for a 9R22.5 tire. 9R22.5 is still a common tire on on two ton bob tail trucks. However stud piloted is becoming a thing of the past.
r
RR
Thanks for the information. I bought a lot of 9Rx22.5 tires from a local school bus depot that were pre-mounted to this and some other styles of rims. I had them dismounted and put on a 1969 Chevy C50. The shop foreman didn't say what these were actually used on, but I gathered that it wasn't the school buses but instead some other type of road work/support equipment. I have no need for and was curious to which vehicles might still be using. As from what was mentioned above, if it is an option, it seems that most newer trucks/buses have switched to the wider rims to take advantage of the more common 11R and 12R tires.
