| | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 15 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 15 | Does anybody know which vehicle these rims fit? 10 hole rimhttp://www.mindspring.com/~lc_controls/images/20180110_113612-c.jpg Stamped on rim: Accuride 27403 From Google search: OEM# 27403 Rim Size: 22.50 X 7.50 Bolt Pattern: 10 Hole on 11.25" Bolt Circle, 8.72" bore Mounting Type: Stud Piloted Dual Offset: 6.44" Material: Steel Number of Hand Holes: 2 Recommended Valve: TR500 Approx. Wt. (lbs): 73 Capacity: 6610 lbs. at 120 PSI. Came with 9R-22.5 tire mounted on it.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | There are lots and lots of trucks with that bolt pattern. Mostly larger or newer than what we usually talk about here.
| | | | | Joined: Dec 2017 Posts: 15 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 15 | I thought most newer trucks with that 10 hole bolt pattern used the 11R or 12Rx22.5 size tires, which I don't think will fit these rims? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Icc123, You are correct 7.50" wide rims are too narrow according to the tire manufacturers to mount 11R tires, I believe a 10R is the widest tire the manufacturers recommend for a 7.50 wide wheel. Wheels with that mounting pattern could be used on lighter trucks than the class eight trucks which use 8.25" wide wheels and mount 11R tires to, hope that clarifies. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The standard of the industry is 8.25x22.5 wheels with 295 75R25 or 275 80 R22.5 tires. The 7.50 x 22.5 would be the wheel for a 9R22.5 tire. 9R22.5 is still a common tire on on two ton bob tail trucks. However stud piloted is becoming a thing of the past. r
RR | | | | | Joined: Dec 2017 Posts: 15 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 15 | Thanks for the information. I bought a lot of 9Rx22.5 tires from a local school bus depot that were pre-mounted to this and some other styles of rims. I had them dismounted and put on a 1969 Chevy C50. The shop foreman didn't say what these were actually used on, but I gathered that it wasn't the school buses but instead some other type of road work/support equipment. I have no need for and was curious to which vehicles might still be using. As from what was mentioned above, if it is an option, it seems that most newer trucks/buses have switched to the wider rims to take advantage of the more common 11R and 12R tires. | | |
