3 members (Otto Skorzeny, TexasA&M48Truck, 1 invisible), 63 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#1287874 11/17/2018 8:35 PM
I have one bad, wobbly spindle on a 52 1/2 ton Chevy truck. I found a cut up 54 frame and dragged it home(the price was t"ake it away"). At the time I only noticed it was a 1/2 ton and had a good third member(just what I had broken in my truck), So home it went. After I had used what I needed. I took some time to see what was still there. Why some one had cut the frame is a mystery. The frame was cut just aft of the E brake cross shaft. A 2 by 6 was put under the frame and over the torque tube and left that way. When I started to have issues with the new King pins(driver side got loose 30 days after I installed it) I started looking at fixes.Loctite, JB Weld and some others. The new bushings were loose in the spindle. And had kina oval shaped themselfes.
That spindle was bad. The fix for the spindle was gonna cost me money I did not have. So I went back to the frame I drug home. It is a 54 late? With a different cross member. The Bell housing mounts are angled. Not flat like the one in my truck. The front axle is in place, and, I wondered what if any thing was different. Removed the Spindles thinking this was the bits I would need. The driver side spindle was short. Why? I don't know. Trimmed off at the cotter key hole. So I had to find out if the left and right spindles were different. I looked hard for a Part Number, that did not go well. I tried E Bay, not much information, but you can buy one for about 150 dollars. Left? Right? That was not so easy. Cleaned them up and compared one to the other. Angles and mounting look the same to me. Getting the King Pins out was a bit of work. But the job was not that bad. So here is what I would like some help with: Are the Left/ Right spindles the same? I did use the "Search" function to see if there was a difference, only the mount bolt diameter(that does not scare me). Any thoughts? Thanks in advance.
Steve
Steve H
Steve_H #1287932 11/18/2018 2:58 AM
Steve, I wish I had the "sure" answer but I don't. However, you may want to check out the online manual, link in the tech section, and check out the parts book. I would think they are the same? The parts book should reveal the truth.
Steve_H #1287934 11/18/2018 3:42 AM
I would have thought they are different (I do not remember where the "stops" are attached), but it looks like knuckles/spindles are the same left/right from 1951-1959?
forging code/number 3708831
part number 3709756
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0522.htm
Steve_H #1288023 11/19/2018 2:10 AM
They are the same. The stop has a tapered bolt which goes through a straight through, non-tapered hole in the spindle so that the tapered stop bolt can go in from either side of the identical spindles.
