3 members (5 Window 9434, BC59, 66flea), 158 guests, and 3 robots.
Topics128,087
Posts1,056,107
Members48,434
#128791 09/22/2006 1:04 AM
I have a '57 1/2 ton. It currently has a 265 (mystery motor) and I picked up a SM420 and driveline for it. The stock rear is in place, but missing the yoke... I think I am going to change direction and build/find a 350 engine and 350 trans. I will probably buy the aftermarket bolt-on motor mount/x-member and tranny x-member. As for the rear end... I know that I will need to upgrade to accomodate the hp/tq of the new engine/trans. Here's where I need help:
Is there a direct bolt in rear that will have the same mounting points and locations for using the existing suspension components? Also, do I even want to keep the stock style suspension with a beefier drivetrain? I think I will want this donor rear to have a 5-lug pattern as well...
Thanks-Dano
smile
my truck gets better every day...every PAYDAY smile
#128792 09/22/2006 3:19 AM
any 5 lug rear will have a different mount setup/position that'll have adapted to yer truck, especially cuz of the pinion angle - other than the 5 stud thing [gonna change the fronts too?], no reason the stock rear won't handle any engine you put in, the only consideration is if you want better gearing for whatever yer gonna do - might find an OD trans for highway speeds
#128793 09/22/2006 2:02 PM
pinion angle is very important!! I remember this from building my 69 Camaro.lol Are internals readily available for the stock rear axles? i know you can buy an aftermarket gear set or adapter for them, but are axles and yokes available?
Thanks-Dano smile
#128794 09/22/2006 2:50 PM
don't know about new axles, never broke one - a buddy has a 55 w/ 427 and the stock axle works fine lifting the front wheels!
the yoke should be available, or there's lotsa used around, and all the bearings are on the shelf - find a good rear end shop and everything will be available - I've talked to a place in Vancouver BC that can fix ya up with near anything including the 3.38 gearset, they may have axles too
#128795 09/22/2006 10:15 PM
Riding in the Passing Lane
I agree. the stock rear end is plenty stought. I would use a 700-4R o-drive trans. if I was going with an automatic.
1972 Chevy c10 Cheyenne Super
#128796 09/23/2006 1:09 AM
Me too. The only thing that might be a problem is if you want a traction aid (Posi), there's none availible on the aftermarket, and the factory units, made from '60-'62, are very rare.
Bill Burmeister
#128797 09/23/2006 1:53 AM
I'm a ways out for getting to the drivetrain still, so I have time to figure it all out...
nothing's impossible, just depends how much time/money I want to spend. I DO like to make informed decisions though to cut down on the headaches wink Red, I checked out the site, looks cool! Thanks again!
Dano smile
