8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | I am changing all 4 leaf springs with some new ones I bought online at http://generalspringkc.com. I also got new shackles, but have a question about what to do for the other bolts. I am unable to find them anywhere. They appear to be a 5/8 x 3-1/2 inch greasable bolt. Not sure the proper name for them and not finding them/much about them online. I have the left rear spring off currently and the gease passage ways are petrified and there is a fair amount of wear/rust on that bolt. Also, looks like my new springs already have a bushing in them. Can anyone tell me if that is true/standard practice or do I need to do anything there before re-installing? Many thanks in advance.
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | They are known as "wet bolts". Do a search for leaf spring wet bolts or for leaf spring eye bolts. You will find a number of "hits" in a range of prices.
Evan
| | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | @JayZed, the bolts from that pic are what I am looking for as I have the shackles. @coilover, I did a search on wet bolts, grease bolts, and zerk bolts. I got a bunch of hits and you were not kidding on range of prices, but was unable to find the size I need. This is exactly what I am looking for. Would love find a cheaper resource than dropping $130 on 4 bolts!
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I had good luck with www.springsnthings.com NAPA sent some that were too long and Rock Auto ordered some that were in a GM box that were also for the wider later springs. | | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | Thank you everyone! Classic parts with our Stovebolt discount for the win. Part of the problem, was I didn't know what I was looking at/for, as I had actually looked at their picture before and it didn't look like mine! This picture shows it with the bushing already on the bolt and i thought it was one piece so their picture looked nothing like the old bolt I had in my hand. Side note, my new leaf springs already has this bushing installed. Classicparts Spring Eye Bolt
