5 members (klhansen, TUTS 59, papas52, 78buckshot, 1 invisible), 91 guests, and 2 robots.
Topics128,186
Posts1,057,308
Members48,468
#128751 10/22/2007 12:36 AM
Does anyone know how to seperate a 39 hood? I just put penetrating oil in the hinges to help it along but not sure how to take apart
thanks
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
#128752 10/22/2007 10:02 PM
The hood halves slide apart at the hinge.
#128753 10/22/2007 11:05 PM
The " side flaps " have a center pin type hinge which you can drive out with enough penetrating oil. The center hinge is an interlocking design with 1/2 sliding inside the other 1/2. Unbolt the hinge from the hood shells and soak it in penetrating oil, then tap one end - should come apart.
1940 Chevy KC 1/2-Ton
