7 members (Leo, Goach2, UtahYork, klhansen, JoeDude, pauld, Wayne67vert), 129 guests, and 4 robots.
Topics128,185
Posts1,057,290
Members48,467
#128751 10/22/2007 12:36 AM
Does anyone know how to seperate a 39 hood? I just put penetrating oil in the hinges to help it along but not sure how to take apart
thanks
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
#128752 10/22/2007 10:02 PM
The hood halves slide apart at the hinge.
#128753 10/22/2007 11:05 PM
The " side flaps " have a center pin type hinge which you can drive out with enough penetrating oil. The center hinge is an interlocking design with 1/2 sliding inside the other 1/2. Unbolt the hinge from the hood shells and soak it in penetrating oil, then tap one end - should come apart.
1940 Chevy KC 1/2-Ton
