7 members (55shaker, 1955 1 Series, Bill Hanlon, Oswald, Greg_H, Ponchogl, Shade Baby),
140
Mod | | | Forums66 Topics128,261 Posts1,058,345 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | In a previous post I stated a problem with my '46 1/2 ton windows. The windows on both sides won't stay up, although the drivers side is clearly worse than the passengers side. The recommendation was to get new window regulators which I now have. To be specific I've purchased the cylinder shaped assembly that the window crank attaches to. Took apart the drivers side door last night and getting the regulator out and I observed a large flat spring that seems to control the window up/down force. I don't see any other springs. Before I cut off the rivits on the old regulator and replace, is this problem a regulator problem or a spring problem? Someone told me to refer to the shop manual but I've been unable to find any specific information on this problem. Am I on the right track here or way off base? Thanks.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I took the complete window crank system out last year and put them in a parts cleaner and kept working them as theres a lot of dirt and grease built up between the large flat surfaces that are joined together that keep the tension from the springs from reaching the end of the regulator arms attached to the rollers. A good cleaning worked on my 46 regulators. Bob T | | |
