2 members (Rmillerfly, 1 invisible),
59
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | a friend showed me an attachment for his pressure washer. it attaches to the end of the gun and the water flow siphons the sand out of a bucket. i am a little concerned the stream of water/sand mix may have a greater tendencey to distort sheetmetal such as grill and fenders. anybody wih experience with this type of sandblasting with an opinion? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds like the perfect way to start rust in all the wrong places
Bill | | | | | Joined: Jan 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 48 | There is a thread about this subject over on the 67-72 Chevy Trucks forum. Tried My New Sandblasting Attachment For Pressure Washer Today (pics)
Joe -------------------------- '67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor ----------- "Tighten until the stud snaps, then back off half a turn."
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | thanks for the replies. from that link to th 67-72 site it looks as if rust could be a problem as red58 suggests if panel is left bare.no one followed up with any major problems so i may give this a try on the 54 grill | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you immediately hit it with a phosphoric acid metal prep wash it shouldn't be a problem.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | 4 on the floor thanks for the reply | | |
