0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I obtained a previously rebuilt non-working 235 engine (1961 block)for parts. It has a 1953 dated head (casting #3701887) that I had cleaned and magnafluxed, showing no cracks. From the parts list I understand the '53 head was used on both splash oiler and high pressure engines. Since I have two trucks that were retrofitted with 235s, both with '58 blocks, I thought I might go ahead and have it rebuilt and store it for possible use later. I understand that the '53 head is probably the least desirable in terms of compression but my trucks are used for relatively light duty and I am not interested in high performance. I did note that the valve cover bolt holes on the manifold side extend into the water jacket of the head. Is that a problem? I would assume thread sealant would be necessary if I used it. Is this a good idea or do I just have an oversized desk ornament? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I thought that all USA 216 and 235 side covers ended at the top of the block?
I thought that 3701887 was a head used on 1953 235 truck engines - 18 head bolts (not 15 bolts as used on earlier 235s and all 216s)?
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | How about using studs in the valve cover bolt holes that hit water and use Loctite or thread sealer for a one-time fix? If it's an 18-bolt head, it should fit the later blocks OK. Jerry
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I went and counted head bolts, it has got 18. I like the idea of using studs, so you don't end up with coolant leaking every time you take off the valve cover. Thanks Tim and Jerry! Kent | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | A 53 235 did not come with 4 bolt valve covers. They came with the two acorn nuts on the top. Someone drilled those holes to accept a later valve cover.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have seen a 1953 235 low pressure engine with that style of head. It was a time of transition. | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | I have seen a 1953 235 low pressure engine with that style of head. It was a time of transition. What aspect of the head are you referring to? Number of bolt holes? Location of valve cover screws? Carl
