Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Cletus1950, Donf, Otto Skorzeny, 55shaker, G508, Guitplayer), 94 guests, and 3 robots.
Topics128,283
Posts1,058,518
Members48,490
I haven't been to the junkyard since the Chinese steel panic. I knew that the yards sold everything, many closed or turned into recyclers. I can't blame them, we sold everything possible, too.
Called one of my former haunts checking on a 14 bolt full floater to put in my 52. The man said he couldn't look one up without an application. (Dang computers!) Told him that was going to take some work on my end, that the last time I went looking I went to the rack with a tape measure. He assured me that must have been several years back. I guess I have outlived my era.
So, I am without a clue about an application, and am hoping someone here can chime in and help.
14 bolt full floater. 3.42 gears. 3/4 or 1 ton with single wheels. Drum brakes. Leaf springs (somewhere I read that they are still on a 36" frame).
This all started as a brake upgrade gone awry, wanting to get rid of the Huck brakes.
Fred
52 3600
69 C-10
have you considered changing over to Bendix brakes? Dave
ASU Offline
If you are looking to upgrade to disc brakes, check this out. http://www.tsmmfg.com/Rear%20Disc/2630eatonl.html Jon
Don’t believe you’ll find what you want with single wheels on it, but you can install single wheels on an axle that had duals.
Also don’t think you’ll find one with exact same spring spacing as your old truck.
Much info about swapping a 14 bolt into an AD truck here.
https://www.stovebolt.com/ubbthread.../14-bolt-axle-swap-info.html#Post1249600
•1952 Chevrolet 3800 pickup
---All pictures---
DLBrooks
DLBrooks
A Square body 73-87 GM 3/4 ton SRW may work. Depending on your wheel a spacer may be needed or not. I used a 75 chevy 3/4 ton 14 bolt in my 1946 3/4 ton. Perches will need to be moved and maybe shock location mounts. I got a 3.73 rear gearing which may be more common. I could not use cab and chassis duals as the perches cannot be moved out on the axle enough. Maybe a full size pickup dually axle may work, dunno.
1959 GMC 100 Fleet
Follow in the DITY
The thread link I provided earlier does explain how to use a Cab and Chassis 14 bolt and how to move the spring perches, also swap to a shallower offset drum if you like, makes more room to bleed the brakes.
I’ve measured the various 14 bolt axles and evaluated the different brake options and combinations possible with the axles from various applications.
If you want to keep the tires same spacing as stock then I strongly believe the Cab and Chassis axle is the best fit in a 48-54 truck.
---All pictures---
The local salvage yard I frequent has their inventory online. Point and click the make, model, and part, then get a list of what they have. I’ve used iron multiple occasions. There is also search engines that you can look at salvage yards across the country..
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Grigg, your thread has a lot of useful data in it. Thanks for sharing. It's going to take some time to wade through.
According to my calculations, width is going to need be 64.25" to 65.25". That is with 16 x 6 GM wheels wearing 7.50-16 tires. That centers 9" of tire in the 12" wheel well. One thing that I am looking for is a listing of widths. With the popularity of the 14 bolt I believe such a page exists.'
Fred
52 3600
69 C-10
The original Eaton axle and the 14 bolt Cab and Chassis axle are within 1/8” of same width, 62-5/8”. Original tires and wheels work great, no reason they wouldn’t. Later model wheels will too, (not real modern though) they’re usually about 1/2” inset from center of wheel.
---All pictures---
The wheels I have are 1" offset. Looks like I could make spacers and use 4" studs, avoiding sectioning the housing. Now I have to track down a differential. Thanks
Fred
52 3600
69 C-10
1/2" difference on one side is probably not an issue, also better to skip spacers if possible.
---All pictures---
Originally Posted by Fred T
...One thing that I am looking for is a listing of widths. With the popularity of the 14 bolt I believe such a page exists.
Yes, this resource, linked early in my thread about the 14 bolt swap. Lots of good info but some questions left unanswered, and some measurements listed differ slightly from my own measurements.
http://www.pirate4x4.com/tech/billavista/14b_bible/
---All pictures---
Went to a friendlier yard today. There are no yards in the area with 3.42 gears. He found some in the surrounding states, but at a cost of $600 minimum plus shipping he didn't recommend them. There 3 in the area with 3.73 gears, priced $375-400. Definitely time to go scrounging the local ads. I had printed out the chart from https://www.roundforge.com/articles/14-bolt-axles-differences-between-srw-drw-and-cc . It gave him something to look up. After selling everything that wasn't nailed down to China, they are finally getting some vehicles back in stock. But with the area economy just now starting to grow, demand for used parts is still high. Many yards are still bare, parting out cars as soon as they cross the scale, and selling the parts while they are still warm.
Fred
52 3600
69 C-10
I’ve bought a few, think $250 is most paid for a real clean one from under a little used RV.
Lots of 4.56, some 4.10, and 3.73 is quite hard to find, I did find one to try.
Any faster gears seems better to buy new than hunt used unless extra lucky.
---All pictures---
I looked at new gears. They come in 3.42 and 3.21. I think I need counseling. drive
Fred
52 3600
69 C-10
Don’t get to excited about fast gears without better brakes and more power.
What do you have for an engine?
My seat of the pants feeling is a 235 or 228 in a 1 ton is good with 4.10, and depending on location, driving style, and what you haul or not then 3.73 might be OK. After that probably need more engine and pretty sure more modern brakes would be appreciated.
---All pictures---
Grigg - 235 with a 3/4 race cam, polished and shaved heads, Pertronix. Stock intake, carb, exhaust. It has just enough rumble to notice with a good ear. I have had it turning 4,500 rpm at 100 mph. Timed by my son, the speedo was pegged at 90. I have hauled some heavy load, but am now osing a walker, so the truck's primary work load is to the lumber yard.
My reason for the change is brakes. My 52 has Huck, and I need drums. Last time I checked used drums were $75, no guarantee they could be turned. I had another HO52 from a 69, thought I could swap the brakes & hub. But I found the 69 axle has an extra inch from the backing plate to the axle end. Was considering having the housings cut, but decided to go with the 14 bolt.
Fred
52 3600
69 C-10
big_eek
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
I found an error in the chart from
Using that, I ordered a 14 bolt, 8 lug, full float, SRW from an 04 Silverado 2500 pickup, should be 65" according to the chart. Actual width was 69". That cost me shipping both ways. frown
Fred
52 3600
69 C-10
Your mistake may have been on the year model. The information might be right for a 14 bolt, now old, but not for the modern AAM axle (also kind of a 14 bolt..)
---All pictures---
