| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 9 New Guy | | New Guy Joined: Oct 2018 Posts: 9 | Well I have been silent but have been searching for the wheel studs. Was to the point of having shamrock bolt make some on there CNC equipment. They suggested Arkansas trailer, I talked to a very helpful individual there name of Gary, He came up with a Gm part number of 704173. This is still available from euclid and is 3.63 inches long just a tad more than needed I hope. (E8961 is the Euc number)
Went to Napa today see if they might have just one or two but Napa has none on hand anywhere. Local guys says it takes them weeks if they have never had on hand. So will try fleetpride tomorrow and see if available thru them. I need that little boy to say a prayer for me. Tomm
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tomm, Have you tried contacting your local GM dealer parts department? I have found no other crossovers other than Napa p/n NOE 6413251. I tried inputting the p/ns at RockAuto, but no results there. I will keep looking for a while but not for too long. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tomm, okay I did a bit more searching, Truck Components, toll free 1-813-933-1166 has their p/n 13-2006 which is an 11/16" thread .755" knurl 3.56" o.a.l. wheel stud which their description says replaces GM. This stud is over 3 1/2" long where the others are only 3 1/4" long, it appears to have the correct knurl diameter. I could not get a price as I am a ludite and couldn't figure out how to get them in my "shopping cart", hope this helps. Please let us know the results. | | | | | Joined: Oct 2018 Posts: 9 New Guy | | New Guy Joined: Oct 2018 Posts: 9 | Thanks for that extra tidbit of information. Don't know what google search terms took you to them.
When I was at Napa yest. the parts guy did call the Gm dealer and it was a no didn't mention any supersession.
Fleetpride was no help today. Will probably give arkansas trailer a shot first since I went to the dance with them.
Tomm | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Looks like these guys have the Euclid studs. I buy a lot from these guys.
https://www.finditparts.com/products/3656713/euclid-e8961
Fleetpride has access to Euclid, but their people are too stupid to find them. Napa isn't much better. I buy over a half a million dollars worth of parts a year for my fleet. I buy just about everything online because I think all the people that could read a catalog have retired.
Dayton Parts has a lot of aftermarket parts. Here is a link to their online catalog. You have to run Adobe Flash to see it.
https://user-5lrz5xi.cld.bz/Product-Catalogs/Dayton-Parts-X-1-Interchange-2016-vp/48 | | | | | Joined: May 2015 Posts: 11,016 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,016 | Here's a listing of Dorman wheel studs & bolts. Might help you track them down.
[url=https://static.dormanproducts.com/document/wheellugstudattributes.pdf]Dorman Wheel Stud Listing[/url]
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2018 Posts: 9 New Guy | | New Guy Joined: Oct 2018 Posts: 9 | Got some studs coming from "finditparts" Thanks crenwelge Had not talked to anyone who used them. Will Post when I get them.
Klhansen, Thanks, I was already aware of the Dorman stuff they don't do the longer stud though.
3B thank you for that link.
Tom | | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | I went to NAPA and got Napa p/n NOE 6413251. It was correct for everything except for the diameter at the thread. It was just a tad bit too big for the nuts. Its for a '54 6100. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | OK to use larger nuts if they fit the wheel properly.
Ed
| | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | OK to use larger nuts if they fit the wheel properly.
Ed Well I should have said it is also just a bit too big to fit the hub. I believe that my studs are 5/8" diameter and the one I bought must be 11/16 | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Will your wheels handle an 11/16 stud? Are your wheels hub or stud centered? If hub has 5/8 holes, easily carefully drilled out to proper size.
Ed
| | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | Will your wheels handle an 11/16 stud? Are your wheels hub or stud centered? If hub has 5/8 holes, easily carefully drilled out to proper size.
Ed I am going to hunt a little more. It's got a .68 diameter at serrated end with I believe to be a 5/8 fine thread which would be 18. I need the thread to be 2.25 inches. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 5/8" is .625", 11/16" is close to what you have.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think he is saying 5/8” thread and larger almost 11/16” over the knurled shank. | | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | I think he is saying 5/8” thread and larger almost 11/16” over the knurled shank. The serrated part is .68". I believe the thread diameter to be 5/8". I say this because I can get a 5/8" nut started but I can only find coarse threaded and the stud is fine threaded. | | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | I did find the correct studs at O'Reilly's and it is a 5/8" thread. | | |
