2 members (Shaffer's1950, baldeagle), 71 guests, and 1 robot.
Topics128,015
Posts1,055,335
Members48,419
#128638 10/16/2007 2:13 AM
Apprentice
Apprentice
ok guys i got my 54 in the garage finally.time for teardown what is the best way for bolt removal burn them out or cut them ?
#128639 10/16/2007 3:17 AM
Burning bolts on the body can make a mess if you're not careful. You will burn the sheetmetal as well. I would drill them out if they are connected to the body. As far as rivets on the frame I always grind the head off and use a big punch to drive the remainder back through.
Be sure to save and catalog all parts you remove.
~Jim
#128640 10/17/2007 8:28 AM
For screws I just usually snap them off by trying to tighten them instead of loosen, then once I take the panel off and can get to the back I use vise grips to get them through the holes.
For bolts I like to apply penetrating oil and use impact. Heat and sheetmetal don't mix.
Paint & Body Shop moderator
