| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | ok guys i got my 54 in the garage finally.time for teardown what is the best way for bolt removal burn them out or cut them ? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Burning bolts on the body can make a mess if you're not careful. You will burn the sheetmetal as well. I would drill them out if they are connected to the body. As far as rivets on the frame I always grind the head off and use a big punch to drive the remainder back through. Be sure to save and catalog all parts you remove.
~Jim
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | For screws I just usually snap them off by trying to tighten them instead of loosen, then once I take the panel off and can get to the back I use vise grips to get them through the holes.
For bolts I like to apply penetrating oil and use impact. Heat and sheetmetal don't mix.
