1 members (TooMany2count),
101
Mod | | | Forums66 Topics128,109 Posts1,056,240 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Does anyone know of a vendor that sells a brake line kit for a 1949 Chevy 3800 Cab/chassis? I'm looking to replace mine to ward off any future issues. Not sure if there is any internal rust, but don't want to gamble. And I'm not sure I want to trial and error teach myself how to bend my own lines. Thanks! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you decide to make your own use copper nickel lines, very easy to work with. If you already thought you might could make them then I’m sure you can do it with copper nickel. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | If you do bend and make your own lines, get a quality double flare tool. It will save you A LOT of aggravation and cursing. | | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | Another vote for copper nickel. Bends and flairs easy. It will work harden but is much more forgiving than steel. Making up lines is really pretty easy. You have the originals for a pattern and it's usually possible to reuse any brake-line blocks, just be sure and get new fittings (and remember to slide em onto the new line before flaring, don't ask why I say this).
Good Luck,
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | One of the selling points is it does not work harden. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | If you do bend and make your own lines, get a quality double flare tool. It will save you A LOT of aggravation and cursing. Suggestions on the best and most inexpensive place to obtain one? Good brands that will do the job w/o creating more problems and frustration AND not break the bank? A quick google was showing sets upwards of $300. I could pay for a pro to do it if I was going to buy that tool. On another thought... any suggestions on cleaning/reusing my existing lines? Initial thought was to replace, but now I'm thinking a rehab may be route I go. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . . On another thought... any suggestions on cleaning/reusing my existing lines? Initial thought was to replace, but now I'm thinking a rehab may be route I go. Go with your initial thought - replace. See what people cost for a "tool set" that is the minimum set needed for your job. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Steel brake lines rust from the inside, too.
Ed
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Without putting a very tiny camera in the lines, there is no way to tell if they are badly corroded inside. I am casting another vote for copper nickel lines. I used them and they seal easier too. The problem I had with th cheap flaring set was that the clamp was not strong enough to securely hold the line in place. The more expensive tool does the job.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | You possibly can “borrow “ the tool from Autozone or O’Reilly auto parts stores.
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Eastwood sells some good brake line tools. You will need a double flare tool, a bender and a tube cutter. They also sell the tubing & fittings, which can be bought locally.. https://www.eastwood.com/tools/brake-tools.html?limit=all
Fred 52 3600 69 C-10
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Even your basic Imperial brand double flare kit with the little buttons will do the job, try to avoid the really cheap imported flare kits. I've used the Easwood lever type flare kit and also a similar one form Fed hill, and one from Brakequip. The Eastwood one is lower quality, the dies and blocks are not finished as nicely, it's still a functional tool. Fed Hill was expensive, very functional. http://store.fedhillusa.com/flaringtools.aspxBrakequip a good balance of price, quality, and also very functional, this is the one I have/keep and use regularly. http://brakequip.com/products/tools/flaring-tools/ | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I know they corrode from the inside too. That's why I was leaning to replace. So, looking at the flaring tools, what is the typical die used? I see DIN, 37*, 45*....I know it depends on the fitting, but what is most common. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | All you need for the original truck and any likely upgrades is 1/4” (possibly 3/16”) 45 degree double flare. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | All you need for the original truck and any likely upgrades is 1/4” (possibly 3/16”) 45 degree double flare. Thanks as always Grigg!! | | | | | Joined: May 2018 Posts: 11 New Guy | | New Guy Joined: May 2018 Posts: 11 | Another vote for copper nickel lines... It's even easy enough to bend and flare the lines from under the truck so you can have a really clean install that only you and your wheel guys will appreciate
1953 3100 Mariner blue (some anyway)
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Jon,
Don't be intimidated with making lines. If you have average mechanical aptitude you can accomplish the job. I am also in the copper nickel camp, the metal bends/flares way easier than other products. The real nice flaring tools exceeded my budget. A run-of-the-mill USA made Sears Craftsman flaring tool (~$40) has worked satisfactorily for me provided that the lines are clamped into the die REAL tight before you start flaring.
Paul | | |
